Ben... - Panther Black Zetec S TDCi [Mk7]
Re: Ben... - Panther Black Zetec S TDCi [Mk7]
Am most likely going away for a couple of years next year. So finance would of been a bad idea!
Im tempted to go. Not sure yet though
Martyboy84
Post by Martyboy84 »
LOVELY car. Fantastic photo's too.
Cheers for the updates!
I just can't get enough.
Chigra
Drives: MK7 Fiesta Zetec S
Post by Chigra »
Hi there mate could you post up a step by step guide or explain how to take the roof liner out and all A,B,C pillars cheers mate :)
Chigra wrote:Hi there mate could you post up a step by step guide or explain how to take the roof liner out and all A,B,C pillars cheers mate :)
A pillars
- pull the rubber seal off around the front of the door frame
- pull the top of the a pillar carefully towards the other side of the car
- pull the base of the a pillar towards the centre of the car and then jiggle it out
B pillars
- remove the small cap with a small flat blade screw driver
- pull off the rest of ye rubber seal around the frame
- look in the gap where the rubber was for the clips attaching the rear interior panels attach to the shell
- use a long screwdriver to push the clips and pull the black rear interior panel towards the centre of the car
- pull out enough so clips all black clips come away from b pillar
B - C pillar join
- use a small flat blade screwdriver to remove screw cover
- undo 3 Phillips screws
- pull down away from b pillar
B pillar
- undo phillps screw behind cover
- use t55 torx driver to remove seat belt restraint bolt
- pull seat belt through b pillar
- replace seat belt restraint to require torque (I don't know this)
C pillar
- remove rubber trim around boot covering edge of c pillar
- use long screwdriver to release any clips visible
- pull away from car being careful not to break any clips
- lift up rear bench seat by pulling front upwards and unclipping the back
- undo t55 torx bolt and feed seatbelt through c pillar
- replace seatbelt restraint bolt to required torque (again I don't know this)
Roof
- remove interior light
- unscrew light surround
- remove sun visors by opening tabs on the mounts and unscrewing
- remove hanger hooks in the back of the car by prising the cap towards the centre of the car then pull out
- remove the plug right in the centre of the roof lining near the back
- then pull out of boot
Just bought new tyres
Went for Kuhmo KU39
Looked on here and I had UniRoyals last time so I thought Id try these
They are the replacement for KU31 which received good feedback
And they're cheap!
Getting my alloys and repowdercoated next week. So they should be on midweek
Jack W
Drives: Fiesta 1.25
Refferer: Rob H
Post by Jack W »
where do you get the push release catch for the secret comparment ?? i need something to fix mine old one i wana do the same thing youve done
Jack W wrote:where do you get the push release catch for the secret comparment ?? i need something to fix mine old one i wana do the same thing youve done
I got the catch from eBay.. I believe i typed something along the lines of 'wood push catch and strike'
Update on the KU39 tyres.
They're better than Hankook S1 Evo, Uniroyal Rainsport 2, Pirrelli P Zero Nero & Yokohomo Parada Spec 2.
They're great in the dry and wet, I can't yet comment on the wear, but they still look brand new after a few thousand miles.
And they're only £50 a tyre
mattgibson
Refferer: Zsoc
Post by mattgibson »
sounding like that, you can't really weigh up why proxes are twice as much.
I am here: http://tapatalk.com/map.php?iumqcl
Jack W
Drives: Fiesta 1.25
Refferer: Rob H
Post by Jack W »
Where did you get the leather from fir the interior pillars and did you use it on the headlining and how easy is it to remove all the pillars and headlining
