The Fiesta MK7 Bulb Changing Guide
mikey_t8
Drives: Zetec 1.4
Re: The Fiesta MK7 Bulb Changing Guide
Post by mikey_t8 »
hi.. i just finished reading your long guide which was very useful indeed.. but i wanted to know, for those who have installend xenon kits, where do you guys put the ballasts?
Ian.ZS.TDCi
Drives: MK7 ZS TDCi
Post by Ian.ZS.TDCi »
What side light bulbs would you recommend to go with Osram nightbreakers
thirdbrother3
Drives: vx220 turbo
Post by thirdbrother3 »
Thought i would provide some clarity on the rear light issue. this is from a 2010 car.
First remove the two torx screws on the outside edge (T25 ideally, but a flat blade can be used in these screws too)
This is interior. the thumb screw cant be reached without moving the carpet trim.
I removed the flat bladed screw, but might not be necessary. if you ease back the boot seal you can see the edge of the carpet to make it easier to pull down
This (right hand on left hand of car) is how far your hand needs to be in to reach the thumb screw
the threads are quite long, but be careful not to drop it
The unit can now be pulled out (towards the rear of the car). Two pegs on the outside of the light are in rubber locators.
Squeeze the clip on the cable socket and pull apart
The bulb holder is removed with a squeeze of two clips
JackClargo
Drives: Fez mk7 zetecs petrol
Refferer: good old google
Post by JackClargo »
Any one got any link for front and back indicators , silvertec or similar ?
anelka
Drives: Fiesta
Re:
Post by anelka »
Rogue_Shadow wrote:Image
With the bulb holder free, you can remove the bulb. This bulb is removed by pulling it out, I'll show you what part pulls away from what.
If that's still unclear what pull away from what, read on. It may become more clear as we install the new bulb.
Is there a trick to get them apart? Mine is stuck, and I dont want to use force to do it. Any help would be much appreciated
Best regards
Tommy
merlyman1966
Post by merlyman1966 »
Just changed headlamp bulb in place, Why do people say you have to remove headlamp?....
levisage
Drives: 2008 Fiesta 1.4 Titanium
Re: Re:
Post by levisage »
Best regards
Tommy
I'm having this problem too, so any help would also be much appreciated. I've tried pulling the bulb out but it's not budging! Is there an extra clip or something or does it just need some force?
By the way I managed to get access to the dipped beam H7 bulb without needing to take the headlamp out.
Cheers,
Mark
zughdi
Drives: ford fiesta
Post by zughdi »
Awesome and Easy Guide to follow! Thanks Rogue_Shadow
Ford2transit
Drives: ford
Refferer: Web
Country: Turkey
Post by Ford2transit »
me too Excellent guide, just put some silvervision indicators and osram nightbreaker plus bulbs in, much better than standard..
