Spraying door cards and surrounding plastics
MrDunleavy
Refferer: Search
Post by MrDunleavy »
Hi everyone, only just registered so take it easy with me! :P
I recently purchased a frozen white Mk7 Fiesta Zetec S (was a cat c and I have repaired it). I have replaced all parts needed including dash and put a nice new set of seats in.
The problem is the dash is now black (rather than the original blue) and the door cards and surrounding sill plastic covers are still a dark blue cover.
Does anyone have any suggestions in regards to getting them sprayed or even purchasing the black plastics? I can take any pics if you need to know what I mean.
Thanks guys :)
P.S - I'll upload a pic of the actual car soon :)
ImageAs promised!
Re: Spraying door cards and surrounding plastics
Post Removed
MrDunleavy
Refferer: Search
Hi patterson,
Thanks for your reply! I need them to match the colour of the dash though....
Wouldn't vinyl wrapping present a colour matching issue?
Post Removed
MrDunleavy
Refferer: Search
Ok thanks a lot mate. Next steps are;
How to remove the inside sill plastic covers (I'm ok with the door cards)
How much is it going to run me? hehe
Post Removed
MrDunleavy
Refferer: Search
If you have the link to the vid that would be awesome!
If you want an exact match you'd be best off seeing if you can buy the door cards in the same colour rather than spraying the ones you've got!
MrDunleavy
Refferer: Search
I have been searching for a while for black door cards but cannot find any! I called Ford and gave them the part number for the cards. I said can I get one in black and they said they cannot give me the colour by part number... :/
