Ford stereo compatility
robslasor
Drives: Ford Fiesta mk7 Style 82
Post by robslasor »
Hi, I have a fiesta style 1.25 82, it has the most basic stereo with no Bluetooth and the smallest screen. If I bought a higher spec ford stereo with Bluetooth and the larger screen, would the Bluetooth just be within the stereo or would I need something else to make it work or would I just be a case of plugging it in?
Thanks
tonyk
Re: Ford stereo compatility
Post by tonyk »
Bluetooth is a separate unit to the stereo and you'll need to programmed to the car for it to work.
StumpyBloke
Drives: Fiesta 1.6 Titanium
Post by StumpyBloke »
And the BT module has its own loom too, which connects to the main dash loom, so I don't think it would be as simple as getting it programmed unless the wiring is there already.
tonyk
Post by tonyk »
That too.
