Wide Arch MK7 ST
tomtom_turbo
Drives: ST
Wide Arch MK7 ST
Post by tomtom_turbo »
So in January i bought my 3rd Fiesta ST (I had a mk6 and a mk7 ST-1 before), a 2015 ST-3 with Mountune MP215
I refurbed and repainted my old sliver fifteen52 tarmacs and made them new and shiny and white, and I think the look pretty sweet on the car as well as fitting my 35mm H&R lowering springs too
ImageFiesta ST MP215 by Tom Acton, on Flickr
Special delivery at work, getting kit together for the wide arches...
tomtom_turbo
Drives: ST
Re: Wide Arch MK7 ST
A quick test fit to see how far the wheels will stick out with the spacers...
I couldn't lower the car all the way down at the front, due to being lowered the arch would have caught on the tyre. So it should actually sit lower than what is shown here :D
tomtom_turbo
Drives: ST
Picked up these beauties while out in the US for work :) Wide arch kit from Fifteen52
Obviously these are designed for the 5 door US spec ST rather than the UK spec 3 door. I'll need to do a fair bit of modification to make them fit to my 3 door
Managed to hand carry them all the way from San Antonio :P
Took some time in my lunch break at work to start figuring out measurements etc for mounting the arches. Gives me a rough idea of what it will look like. Getting excited!
This gives a better idea of the overall look:
tomtom_turbo
Drives: ST
Work is underway to modify the rear arches, making them into a single piece and losing the door gap. They've been bonded together and bolted to make sure they are as strong as possible. The next step is to sand all the filler and make a nice smooth arch again
And couldn't resist a quick offer up to the car
The plan is to incorporate brackets into the arches so that they can be bolted to the body work. The existing arches will be beaten out to make room for the extra width of the wheels
tomtom_turbo
Drives: ST
Arches on the driver side have been cut back to make room for the wider stance. The fifteen52 wide arches have been cut at the joins between the bumpers and bodywork, brackets have been made and attached to the wide arches and they have been bolted to the car.
So now its a case of repeating for the passenger side, then painting and final mounting :D Not too long now...
tomtom_turbo
Drives: ST
So the end is in sight with the wide arch kit now. There's still some fettling to be done to get everything sitting flush, but this will give you an idea of the end result. It's definitely a much more aggressive look
tomtom_turbo
Drives: ST
So guys, the arches are done and fitted!!
Really happy with the result, just have to be even more careful when parking near curbs now!
:D
tomtom_turbo
Drives: ST
Spent all day Sunday fitting my ap coilovers. Good job the weather was amazing!
Rear fitted:
So shiney!! :D
tomtom_turbo
Drives: ST
Update:
Painted the wheels black and sprayed on some Speedhunters tyre bombs
ImageDSC_0728 by Tom Acton, on Flickr
Looked pretty good at Players
Elpanda82
Country: England
Post by Elpanda82 »
Loving this car. Saw a mk 7 at the weekend with these wheels on in white they look spot on.
