It is very helpfull when other members post guides and information that may be of use too you, however you must remember that the information provided here is often down to a users personal experience, expertise and sometimes oppinion.
As far as im concerned all the guides on here are very good but can i please urge anyone following them or anyone doing any work on any car for that matter, to follow some basic safety precautions.
- Don't work under a car that is only held up by a jack. They are often unstable and are designing for jacking, not supporting. Put some axle stands under the car.
-If spraying or using chemicals, make sure your in a well ventilated area. Certain fumes can cause damage to you if theres not enough ventilation.
-When angle grinding something, use protective glasses and rigger gloves. Angle grinder discs falling apart at 10,000rpm is not pretty. Ive seen it happen.
-Dont bodge it, you may be putting your own and/or other peoples live at risk.
-If your not sure, ask someone that knows better than you!
The information here is to be provided as purely a guide, we cannot be held responsible for any damage or loss you may cause. However im sure if you use your brain you will be perfectly ok.
Many thanks
Fiesta Mk7 .com Team
Following guides/advice. Safety Precautions - Please Read
